Lessons learned on my first Leathercraft coaster
silasrobinson
I just finished my first leathercraft project and this it's a little coaster and even though it is not perfect, I am glad I stuck with it. I jumped right in and got a beginner set, but the whole process was much harder than I expected and I am hoping some experienced people can tell me if my materials were the reason.
I know I should have stitched closer to the edge next time but the leather scraps I bought, which is the white side of the coaster, were so soft that I could barely even mark the cutting line with my awl. And the black material came from a thrift store purse, which I found out was stuck to a layer of foam. My cheap contact adhesive dried up and got crusty before I could stick the two halves together so I had to put on a second layer and stick them when it was still wet, but it held together okay. I had a really hard time making the holes for the stitching, and I wonder if that was because of the low quality materials or if my mallet was too soft for punching through. What are the best, easiest-to-work-with types of leather that you would recommend for a true beginner to practice on?
Afaik, most beginners often prefer vegetable tanned leather that is about 2–3 millimeters thick because it is easier to handle. If you want to experiment, just get a small offcut of veg tan from a leather supplier are affordable. It also provides a steady surface for practicing stitches along the edge without dealing with stretching or hidden layers.
for beginners, the best leathers are the VegTan for learning structure/tooling (especially thicker bellies/shoulders for cheap practice), I also like ChromeTanned for soft, pliable projects (bags/wallets),
try to start with small, inexpensive pieces like belly sections to learn cutting, stitching, and dyeing without high cost
