What kind of equipment will I need?
Edisingeddy
New member
I know I'll need things to cut, stitch and stuff like that, but what about the leathercraft specific stuff? Would I need a machine and what kind? Or do you think it's better to start by hand and then move over to the machines?
Hey, welcome to the craft! For the basics, you'll need a good utility knife and a cutting mat, a few different awls, and some needles and thread. For a beginner, it's almost always better to start by hand. This really helps you understand the material, how the tension works, and gives you a feel for what you're doing. So for the more specific leathercraft tools, start with a basic one for punching holes, an edger for beveling, a slicker for finishing your edges, and a groover for making a nice line for your stitches.
Don't worry about a machine right away! You can always invest in it later on if you find you're really enjoying it and want to speed up production. For now, focus on the fundamentals with hand tools and have fun! You'll be surprised how much you can do with a small, quality set!
Some of us NEVER move over to machines. :giggle:
I confess I tried once, to convert my Singer Spartan (circa 1927) to sew leather. OH the machine had no problem with the leather, but on the widest stitch setting the seam was still too tight, and ended up making the leather like perforated paper.
I use a knife, steel shears, glover's needles, regular needles, stab awls, and artificial sinew (or sometimes real sinew). For dying I use Fiebing's leather dye, and dauber, plus saddle soap and a piece of wool. I like brass buckles or rings if I'm using buckles or rings. Straps are either leather or hemp.
LD
When starting leathercraft, the best approach is to begin with hand toolscoz this helps you learn the material and techniques without a large initial investment. You'll need some basic cutting tools like a utility knife and a cutting mat, along with a metal ruler. For stitching, essential items include a non-marring mallet, stitching chisels to make even holes, leather needles, and waxed thread. A stitching pony and hole punches are also highly recommended to make the process easier and more professional. Machines are a significant expense and are generally only needed for high-volume work or very thick projects. Starting by hand allows you to produce high-quality work and master the fundamentals, giving you the experience needed to decide if a machine is a necessary future investment.
